Введение
This guide shows how to replace a speaker from the main array of a Sonos Playbase.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Pro Tech Toolkit$74.95
Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
Disconnect the main speaker array from the main board, by pinching and and pulling the tab out.
Remove the side speakers from the green printed circuit board (PCB) running along the top of the main speaker array by pinching and pulling out the connector.
Remove the damaged speaker from the array socket, by grasping the speaker with one hand, the array with your other and pulling outward.
