Введение
This guide will tell you how to replace the flash assembly of the a6000 camera if it breaks or gets damaged.
Выберете то, что вам нужно
Position the camera with the flash assembly facing upwards.
Locate the flash assembly.
Open the flash assembly.
Using the Phillips #00 screwdriver, remove the single screw beneath the flash assembly.
Position the camera with the LCD screen facing upwards.
Pull back the LCD Screen.
Using the Phillips #00 screwdriver, remove the three screws beneath the viewfinder.
Position the camera with the HDMI port facing upwards.
Using the Phillips #00 screwdriver, unscrew the single screw on the left side of the camera body.
Position the camera with the top panel facing upwards.
Carefully separate the top of the camera from the body using plastic opening tool.
Position the camera so the top panel's underside is facing you
Using the Phillips #00 screwdriver, unscrew the screw underneath the flash assembly.
4 участников успешно повторили данное руководство.
3 Комментариев
Anyone know where to get the flash? My daughter’s has the “won’t stay closed” problem so common to the a-series and I need to replace it.
Thanks, good guide but please update it according to Jürgens comments or there is a big risk people will break their top panel.
David: I got the flash unit from AliExpress, but you can find it on Ebay as well.
Thanks for the guide! I had to open additional 2 more screws inside the battery compartment. and only had to remove 2 bottom screws on Step 8 (instead of 3). Replaced the flash unit without any issue. Thank you!
