Введение
Are the videos in your device corrupted? Maybe you need so more space for your spectacular videos? Here is a simple guide on how to remove or replace a memory card in the Sony HDR-AZ1.
To access the memory card, pull open the small dust door on the bottom right of the back of the camera.
Push inward on the back of the memory card with the tip of your finger until you feel a click and release.
Pinch the rear of the memory card that is protruding from the slot and pull outwards until the memory card is removed.
To place a new memory card in, follow these instructions in reverse order.
