Введение
This guide can help you open the front plate of your Sony Alpha A5100. For this guide, you will need a plastic opening tool and a Phillips PH00 screwdriver head. You will need to be gentle while opening up the plate.
Slide the power switch on the top of the camera to "off."
Turn the camera over to the bottom, and push the latch towards the side marked "open" to release the battery cover.
Push the blue spring-loaded lever to release the battery.
Remove the battery from the camera.
Remove one 2mm Phillips #00 screw from the flash plate cover.
Use the spudger to pop the plate off.
Remove two 2mm Phillips #00 screws on the side of the camera.
Pop the memory card door open by gently lifting the door up.
Remove two 2mm Phillips #00 screws from the side of the camera.
Remove three 2mm Phillips #00 screws on the bottom of the camera.
