Введение
This guide provided instruction on removing the motherboard and should only be followed if a compatible replacement is available or subsequent repair procedures require its removal.
Выберете то, что вам нужно
Remove this final screw from the memory card compartment.
Remove the chassis by pulling the back cover away from the camera.
Gently but forcefully lift up on the parallel cable connecting the two halves of the camera.
After removing the backing from the camera. Remove the two final screws in the memory compartment area.
Detach the facing for the memory dock.
6 участников успешно повторили данное руководство.
