Введение
This guide will show you how to unlock the latch that holds the battery compartment, and how to eject the battery from the Sony Alpha NEX-5N.
Flip the device upside-down and gently place it down on a flat surface.
Locate the battery compartment, which is indicated by a grooved latch.
Push the latch to the right so that the arrow is positioned above the word "Open". The door should then flip upward.
With the battery compartment latch open, locate the lock lever.
Press the lock lever to the left. This will eject the camera battery.
