Введение
The E-mount, the interface between a camera body and a lens, can be easily replaced when it's time to change a dented or non-functioning E-mount. E-mount is also referred to as a lens mount when the camera it is attached to has an interchangeable lens.
Выберете то, что вам нужно
Unscrew the 4 silver 1.2 mm Phillips #000 screws along the front outer lens mount.
Detach the outer lens mount ring.
Using your fingers, pull out the first black spacer ring.
Repeat the previous step for the second silver spacer ring.
Unscrew the 2 silver 1.2 mm Phillips #000 screws on opposing sides in the lens ring area.
Using your fingers, easily pull off lens housing. This will complete the removal of the E-mount.
