Введение
The top panel can be cracked, and it's removal is often needed to access other parts under the top panel.
Выберете то, что вам нужно
Use a Phillips head 000 screwdriver to remove the 4.0mm screw inside the USB port.
Use a Phillips head 000 screwdriver to remove the one 4.0mm screw on the side opposite of the USB port near the shutter button.
Open the flap at the top of the camera.
Use a Phillips head 000 screwdriver to remove the two 4.0mm screws inside.
Еще один человек закончил это руководство.
