Введение
The LCD screen can be pulled out to a couple of different angles. However, be careful when angling it because it does have restrictions. Doing so past those restrictions will break the LCD bracket holding it in place.
Выберете то, что вам нужно
Lift the LCD screen to unscrew the 2 screws on its underside.
What is the screw size on these on the screen because I lost some and I am trying to replace it?
8 участников успешно повторили данное руководство.
4 Комментариев
And the how do you change the LCD screen please ? How to remove it ?
I have the exact same question, I need to change the screen with flex cable as well. Thanks, there isn’t a lot of info on the a7s 2, it’s all a7r out there
Hello. My LCD backlight stop working after water came into the camera (snow). With a flash light I was able to determine it is the backlight since I was able to detect some menu items on the screen. I bought a replacement LDC unit, my thinking was that the backlight itself was damaged and a new one would do the trick. After replacing the screen, I have the same probleme. So I suppose my problem come from deeper in the camera. The camera itself do not command the backlight to turn on. Is there something I can do? any more troubleshooting?
Thanks!
What size screws!?
