Введение
User is unable to securely mount their camera onto a tripod. A loose tripod socket can cause an unstable connection between the tripod and camera, which can contribute to blurry pictures and the possibility of your camera falling off the tripod.
Выберете то, что вам нужно
Orient your camera so that you are looking at the bottom portion.
Using the JIS #00 screwdriver, remove the 7 screws that are securing the metal plate to the bottom of your camera.
Remove the metal plate. Sometimes this plate can become stuck and hard to remove. Use tweezers to separate the plate from the bottom of the camera.
Flip the plate to the opposite side exposing the aspect that was just inside of the camera.
Use the screwdriver J00 to tighten the 3 screws surrounding the tripod mount.
