Введение
In the situation that your Sony BDP-BX510 motherboard is not working, you may need to replace it. This guide will provide you with the steps required to safely remove your motherboard for replacement. The tools that are needed include a Phillips #2 screwdriver, Phillips #1 screwdriver, tweezers, and metal spudger.
Выберете то, что вам нужно
Plug in the device to turn it on, then press the eject ( ⏏ ) button to open the tray.
To remove the tray cover, hold both sides of the tray cover and gently apply a downward pressure.
Apply slightly more pressure to the left side until it unhooks then unhook the right side.
Close the disk tray by pressing the eject button again, then power off the device and unplug it.
Turn to the back of the device.
Remove the two 7mm Phillips #2 screws.
Slide the two plastic covers on both sides of the device towards the back of the device to remove them.
Turn the device so you can see the bottom.
Unclip the three black plastic clips on the bottom of the device.
Unclip one clip on each side of the device.
Pull out these cables from the motherboard.
Using tweezers, lift the black tab on the connector of the large 45 pin connector on the motherboard.
Pull the large 45 pin ribbon cable out of the connector in the motherboard.
Remove the two 5mm Phillips #1 screws.
Lift the side of the power module and remove it.
Remove the three 5mm Phillips #1 screws.
Turn the device over to the backside.
Use tweezers or metal spudger to take off the metal clasp for the metal brace near the center on the bottom of the device.
Remove the metal brace.
Remove the silver 3mm Phillips #1 screw.
Remove the black 7mm Phillips #1 screw.
Lift the side of the motherboard and pull it out.
