Sony BDP-BX520 Port Board Replacement
Выберете то, что вам нужно
  1. Sony BDP-BX520 Port Board Replacement, Disc Tray Cover: шаг 1, изображение 1 из 1
    • Plug in the Blu-Ray player, then press the power button, making sure the Blu-Ray player is powered on.
    • Press the eject button on either the top of the Blu-Ray player or on the remote to open the disc tray.
  2. Sony BDP-BX520 Port Board Replacement: шаг 2, изображение 1 из 1
    • Grab the sides of the disc tray cover and carefully pull each side upwards, starting with the left side. This will unhook the cover from the tray.
  3. Sony BDP-BX520 Port Board Replacement: шаг 3, изображение 1 из 1
    • Close the disc tray, then power off and unplug the Blu-Ray player.
  4. Sony BDP-BX520 Port Board Replacement, Front Panel: шаг 4, изображение 1 из 1
    • Insert the nylon or metal spudger under the clip on the side near the front of the device. Lift the clip so it is free from the device.
    • Lifting these clips may require you to hold one clip open while you move on to the next clip.
  5. Sony BDP-BX520 Port Board Replacement: шаг 5, изображение 1 из 1
    • Flip device over so the bottom faces you.
    • Insert the nylon or metal spudger and lift the two clips on the bottom of the device.
  6. Sony BDP-BX520 Port Board Replacement: шаг 6, изображение 1 из 1
    • Lift the clip on the opposite side of the device with the nylon or metal spudger.
  7. Sony BDP-BX520 Port Board Replacement: шаг 7, изображение 1 из 2 Sony BDP-BX520 Port Board Replacement: шаг 7, изображение 2 из 2
    • Grasp the front case firmly and lift from the rest of the device.
    • Lifting may require some force.
  8. Sony BDP-BX520 Port Board Replacement, Port Board: шаг 8, изображение 1 из 2 Sony BDP-BX520 Port Board Replacement, Port Board: шаг 8, изображение 2 из 2
    • When handling circuit boards like the motherboard and port board, make sure to only touch them on the sides.
    • Locate the large ribbon cable connecting the port board to the motherboard.
    • Detach the cable from the motherboard by carefully pulling upward on the cable.
  9. Sony BDP-BX520 Port Board Replacement: шаг 9, изображение 1 из 1
    • Using the Phillips #2 screwdriver, unscrew the silver, 8mm screw holding the board in place.
  10. Sony BDP-BX520 Port Board Replacement: шаг 10, изображение 1 из 2 Sony BDP-BX520 Port Board Replacement: шаг 10, изображение 2 из 2
    • Using the nylon or metal spudger, carefully unclip the port board from the side of the player.
  11. Sony BDP-BX520 Port Board Replacement: шаг 11, изображение 1 из 1
    • Carefully pull the port board free from the Blu-Ray player.
Заключение
Еще один человек закончил это руководство.
Collier
Участник с: 01/31/15
352 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 8-41, Amido Winter 2015 Участник Cal Poly, Team 8-41, Amido Winter 2015
CPSU-AMIDO-W15S8G41
4 членов
Автор 8 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 6
За всё время: 335
