Введение
This guide requires only simple tools, like a screwdriver and metal spudger. Be careful when handling circuit boards to ensure the device does not become further damaged.
Выберете то, что вам нужно
Plug in the Blu-Ray player, then press the power button, making sure the Blu-Ray player is powered on.
Press the eject button on either the top of the Blu-Ray player or on the remote to open the disc tray.
Grab the sides of the disc tray cover and carefully pull each side upwards, starting with the left side. This will unhook the cover from the tray.
Insert the nylon or metal spudger under the clip on the side near the front of the device. Lift the clip so it is free from the device.
Flip device over so the bottom faces you.
Insert the nylon or metal spudger and lift the two clips on the bottom of the device.
Lift the clip on the opposite side of the device with the nylon or metal spudger.
Locate the large ribbon cable connecting the port board to the motherboard.
Detach the cable from the motherboard by carefully pulling upward on the cable.
Using the Phillips #2 screwdriver, unscrew the silver, 8mm screw holding the board in place.
Using the nylon or metal spudger, carefully unclip the port board from the side of the player.
Еще один человек закончил это руководство.
