Введение
The disk tray belt is what allows the disk tray to open and close. When the eject bottom is pressed there are two gears that rotate with the belt. If this belt is broken, cracked, or missing both gears will not rotate together causing the tray to no longer open. To fix this issue this belt can be replaced using an O ring or another tray belt of the same size.
Выберете то, что вам нужно
Use a #1 Phillips screwdriver to remove the three screws located in the back of the device.
Pull the top cover off by sliding back from the device once the screws have been taken out.
Lightly lift off the hook on both front rear side and the bottom of the device to remove the front panel
Remove the two screws that attach the disk drive to the frame using a #1 Phillips screwdriver.
Remove the top of the disk drive by gently lifting up on the four latches located on both sides of the disk drive while lifting upwards.
2 участников успешно повторили данное руководство.
