Введение
Every battery runs out of power eventually after many uses. This guide will show you how to easily replace the battery on your Sonly Bloggie 3D.
Запчасти
Никакие детали не требуются.
  1. Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Use a plastic opening tool to pry the cover open. After the the cover is partly open as shown, remove the cover with your hands.
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  3. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board. Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
    • Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
  5. Use a plastic opening tool to loosen the back cover off the device. Once the back cover is loose, remove it gently by hand.
    • Use a plastic opening tool to loosen the back cover off the device.
    • Once the back cover is loose, remove it gently by hand.
  6. Remove the battery with your fingers. Remove the battery with your fingers.
    • Remove the battery with your fingers.
Заключение
Timothy Tran
Участник с: 30.01.2013
1 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 7-12, Maness Winter 2013 Member of Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
5 членов
Автор 6 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 3
За 30 дней: 10
За всё время: 1,220
