Введение
This will help you to remove the front cover so you can get to the other parts of the Bloggie 3D Camera.
Запчасти
Никакие детали не требуются.
  1. Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  3. Use a plastic opening tool to pry the cover open. After the the cover is partly open as shown, remove the cover with your hands.
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
Заключение
Robert Tam
Участник с: 30.01.2013
6 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 7-12, Maness Winter 2013 Member of Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
5 членов
Автор 6 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 241
