Введение
This will help you to remove the front cover so you can get to the other parts of the Bloggie 3D Camera.
Выберете то, что вам нужно
Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
Use a plastic opening tool to pry the cover open.
After the the cover is partly open as shown, remove the cover with your hands.
Почти готово!
Заключение
