Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
The USB is a very important part of the Sony Bloggie as it is the only way to get your movies from the camera to a computer. This guide will show you how to install a new USB drive in the Sony Bloggie 3D.
  1. Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
    • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  2. Use a plastic opening tool to pry the cover open. After the the cover is partly open as shown, remove the cover with your hands.
    • Use a plastic opening tool to pry the cover open.
    • After the the cover is partly open as shown, remove the cover with your hands.
  3. Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board. Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
    • Using your hand, or a pair of tweezers, remove the ZIF connector by gently pulling it out of the dock on the circuit board.
  4. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Shop Kits
    Enough RAM
    For All The Tabs
    Shop Kits
  5. Use a plastic opening tool to loosen the back cover off the device. Once the back cover is loose, remove it gently by hand.
    • Use a plastic opening tool to loosen the back cover off the device.
    • Once the back cover is loose, remove it gently by hand.
  6. Once the back cover is removed, by using the opening tool, remove the following screws using a Phillips #00 screwdriver. Two 4.0mm Phillips #00 screws
    • Once the back cover is removed, by using the opening tool, remove the following screws using a Phillips #00 screwdriver.
    • Two 4.0mm Phillips #00 screws
    • One 8.0mm Phillips #00 screw
    • One 9.5mm Phillips #00 screw
  7. Using a spudger, remove the clips of the metal casing from each end of the USB drive. Using a spudger, remove the clips of the metal casing from each end of the USB drive.
    • Using a spudger, remove the clips of the metal casing from each end of the USB drive.
  8. Carefully lift the USB drive off of the peg that it is attached to. Carefully lift the USB drive off of the peg that it is attached to.
    • Carefully lift the USB drive off of the peg that it is attached to.
  9. Now that the USB component is on its own, untangle the ribbon from inside the device.
    • Now that the USB component is on its own, untangle the ribbon from inside the device.
  10. Now remove the ZIF connector from the device using a pair of tweezers.
    • Now remove the ZIF connector from the device using a pair of tweezers.
Заключение
Craig Sweet
Участник с: 11.01.2013
1 Репутация
1 руководство автора
Команда
Cal Poly, Team 7-12, Maness Winter 2013 Участник Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
5 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 356
