Введение
If the lens of the video camera cracks or becomes cloudy, replacing it can be costly and confusing. This guide shows how you can access the lens assembly on your own to make a quick replacement. To get to the lens assembly, you will need to have already removed the battery and the outer casing.
  1. Lift viewfinder to access battery pack.
    • Lift viewfinder to access battery pack.
  2. Press the battery release button. While pushing the battery button, slide the battery to the left.
    • Press the battery release button.
    • While pushing the battery button, slide the battery to the left.
  3. Pull the battery pack out of the video camera.
    • Pull the battery pack out of the video camera.
  4. Open the cassette cover. Unscrew 14 screws located on the outer casing. Three are located on the top face 2x6.8mm and 1X4.54mm, three on the left face 1x4.54mm,1x5.3mm and seven on the bottom face 5x4.54mm and 2x6.77mm. Unscrew 14 screws located on the outer casing. Three are located on the top face 2x6.8mm and 1X4.54mm, three on the left face 1x4.54mm,1x5.3mm and seven on the bottom face 5x4.54mm and 2x6.77mm.
    • Open the cassette cover.
    • Unscrew 14 screws located on the outer casing. Three are located on the top face 2x6.8mm and 1X4.54mm, three on the left face 1x4.54mm,1x5.3mm and seven on the bottom face 5x4.54mm and 2x6.77mm.
  5. Continue removing screws. Five on the right side, from bottom to top, 3x4.54mm 2x5.70mm. One on the backside 1x4.54mm. Continue removing screws. Five on the right side, from bottom to top, 3x4.54mm 2x5.70mm. One on the backside 1x4.54mm.
    • Continue removing screws. Five on the right side, from bottom to top, 3x4.54mm 2x5.70mm. One on the backside 1x4.54mm.
  6. Pull off the plastic tape cover by lifting it up and out of the camera base.
    • Pull off the plastic tape cover by lifting it up and out of the camera base.
  7. Disconnect the mic assembly by pulling it away from the camera base.
    • Disconnect the mic assembly by pulling it away from the camera base.
    • Do not pull too hard as the wires are still connected.
  8. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  9. Pull the bottom part of the case away from the camera.
    • Pull the bottom part of the case away from the camera.
  10. Remove the three marked screws located on the right face of the video camera 3x4.54mm.
    • Remove the three marked screws located on the right face of the video camera 3x4.54mm.
  11. Remove the one circuit board screw at the front of the video camera 1x3.6mm.
    • Remove the one circuit board screw at the front of the video camera 1x3.6mm.
  12. Pull the audio/video inputs underneath the microphone assembly. The inputs should still be connected to the circuit board.
    • Pull the audio/video inputs underneath the microphone assembly. The inputs should still be connected to the circuit board.
  13. Remove two remaining case screws on the front of the camera 2x3.63mm.
    • Remove two remaining case screws on the front of the camera 2x3.63mm.
  14. Using metal tweezers, pull out the plastic connector box on the front side. Again use metal tweezers to pull out the connection box on the bottom of the camera. The right side of the case can now be removed by pulling it to the right.
    • Using metal tweezers, pull out the plastic connector box on the front side.
    • Again use metal tweezers to pull out the connection box on the bottom of the camera. The right side of the case can now be removed by pulling it to the right.
  15. Remove three screws from the circuit board on the left side of the video camera 3x3.6mm.
    • Remove three screws from the circuit board on the left side of the video camera 3x3.6mm.
  16. Using metal tweezers, pull out the plastic connector box. Pull up the circuit board. Be careful, it should still be connected to a band wire.
    • Using metal tweezers, pull out the plastic connector box.
    • Pull up the circuit board. Be careful, it should still be connected to a band wire.
  17. Remove three 2x4.45mm 1x5.36mm screws around lens assembly. Remove three 2x4.45mm 1x5.36mm screws around lens assembly. Remove three 2x4.45mm 1x5.36mm screws around lens assembly.
    • Remove three 2x4.45mm 1x5.36mm screws around lens assembly.
  18. Remove three screws from the bottom part of the lens assembly 2x6.00mm and 1x5.46mm. Be careful not to break band wires. The bottom two are gold screws.
    • Remove three screws from the bottom part of the lens assembly 2x6.00mm and 1x5.46mm. Be careful not to break band wires. The bottom two are gold screws.
  19. Lift lens assembly off large circuit board. Unscrew three top screws 2x5.31mm and 1x6.07mm.
    • Lift lens assembly off large circuit board.
    • Unscrew three top screws 2x5.31mm and 1x6.07mm.
    • Unscrew last remaining screw with Phillips #000 screwdriver 1x6.06mm. Lens should detach from lens assembly.
  20. Once lens has been removed from lens assembly, replacement or repair is possible.
    • Once lens has been removed from lens assembly, replacement or repair is possible.
Заключение
2 участников успешно повторили данное руководство.
Andrew
Участник с: 23.01.2011
58 Репутация
1 Guide authored
Команда
Cal Poly, Team 11-25, Maness Winter 2011 Member of Cal Poly, Team 11-25, Maness Winter 2011
CPSU-MANESS-W11S11G25
4 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 12
За 30 дней: 27
За всё время: 2,371
