Введение
This guide will show how to remove the back panel to be able to work inside of the device.
Before any repair work can be done one must remove the device for the vehicle. To do so follow this link to see a general vehicle removal of a stereo system.
Выберете то, что вам нужно
Press down on the clip like you would an Ethernet cable.
Rock harness side to side, pulling gently towards you until harness detaches.
Remove four 9.5mm Phillips #00 (black) screws from back panel.
Remove two 7.5mm Phillips #00 (black) screws from back panel.
2 участников успешно повторили данное руководство.
