Введение
This guide will show how to remove and replace the face-plate eject lever on the device.
Before any repair work can be done one must remove the device for the vehicle. To do so follow this link to see a general vehicle removal of a stereo system.
Выберете то, что вам нужно
Remove two 4.9mm Phillips #00screws on the front of the device.
Remove two 7.5mm Phillips #00screws on the front of the device.
Rotate device 90 degrees to either side.
Use the plastic opening tool to pry open the top and bottom tab respectively.
Repeat on opposite side.
2 участников успешно повторили данное руководство.
