Выберете то, что вам нужно
Rotate the motherboard toward you to show the cables on the opposite side of the motherboard.
The motherboard is removed. To install the new motherboard, follow the directions in reverse.
Один комментарий
I have a full reset whenever I take the battery out to recharge it. Given that all replacement motherboards will be as old as the unit, is there anyway to fix the board (I presume it’s a capacitor or super cell that keeps the charge long enough to swap the battery over normally?). The three cells seem to be soldered onto the board, but I presume could be replaced?
Anyone know of a way to fix this?
