Введение
The following guidelines will show the step-by-step procedure on how to remove and replace the Sony Clie thumb dial.
Выберете то, что вам нужно
First, place the device with the screen side facing down. Remove the 2 screws from the thumb dial panel located on the upper right hand side.
Follow ribbon wire to locate where it plugs into the board. The plug is a flat black square.
Почти готово!
Заключение
