Введение
Rear Cover Removal allows the inside of the Clie to be exposed for further replacement of internal components
Выберете то, что вам нужно
Using Phillips screwdriver, remove 4 screws from the rear cover.
Remove 1 screw from the right side.
Remove 1 screw from the top
Slowly pull rear cover from device being careful not to pull the speaker connection wire.
Remove speaker wire from device.
The rear cover is now separated from the device.
