Введение
If the camera lens is unrepairable, you may just need to replace it with a brand new one. This is how you take it apart before you insert a new one.
Выберете то, что вам нужно
Using a Phillips #0 screwdriver, remove all of the screws from the back panel casing.
Take a hold of the right side of the LCD screen and lift it towards the left.
Unplug the large conductive tape attached to the screen.
Remove the LCD from the device.
Using a Phillips #0 screwdriver, unscrew the four 4.24 mm black screws off the blue panel on the right side.
Disconnect the white conductive tape.
Remove the blue panel.
Use tweezers to remove the three conductive tape strips on the right side.
Use tweezers to remove the orange conductive tape located below the shutter.
Unplug the three ZIF connectors from the motherboard.
Flip up the blue overlapping board at the top.
Use tweezers to disconnect the remaining connectors.
Use a screwdriver to remove 5 screws on plastic panel.
Remove the single screw on the silver panel in the center.
Use tweezers to remove the blue control panel.
Remove the lens from the camera.
3 участников успешно повторили данное руководство.
