Введение
Removing the Sony Cyber-Shot DSC-S90 battery terminal is considered to be a moderately difficult process. This is because through the process of removing the battery terminal, the disassembly of almost the entire camera is required. Despite the enhancement of difficulty in this 15 step guide, the only tool needed is the J00 screwdriver.
Выберете то, что вам нужно
Hold down the "open"button (gray oval with arrow pointing upwards) on the battery port door.
While holding the button downwards, slide the door upwards to unlock and open the door.
Remove the 2mm Phillips #00 screw under the battery port door.
Remove the 2mm Phillips #00 screw towards the right of the bottom-side of the camera.
Use an opening tool to unlock the front case from the main body of the camera. Use the tool on the right side and bottom of the camera with the LCD screen facing you.
Use an opening tool to unlock the front case from the main body of the camera. Use the tool on the top of the camera.
Release all clips and latches keeping the casing in place using a spudger, opening tool, or screwdriver.
Disconnect the ribbon cables on top of the battery terminal using a spudger or screwdriver.
Disconnect the remaining ribbon cable on the side of the camera using a spudger or screwdriver.
Use a spudger or screwdriver to unhinge the clips. This releases the battery terminal.
Once the battery terminal is unclipped, pull this ribbon cable out with a spudger or screwdriver to finish freeing the battery terminal.
