Введение
If the battery is not charging and/or not holding a charge, or if the device has taken in water, you are going to want to remove and replace the battery. This guide will show you how to remove the battery so that it may be replaced.
Using your finger, slide the release catch to unlock the battery/memory card cover.
Еще один человек закончил это руководство.
