Введение
This repair will solve any problems related to flash malfunctions. For example if the flash is not responding or the flash is not as bright as it should be, this repair will fix these issues.
Выберете то, что вам нужно
Use a Phillips #0 screwdriver to unscrew the six 2mm screws on the outer case of the camera.
Инструмент, используемый на этом этапе:Tweezers$4.99
Remove the protective black cover layer with your hands and set it aside.
The ZIF connector can be removed by flipping the small black holder into the upright position and then sliding the ribbon cable out carefully.
Once this has been done, use tweezers to unplug the flat topped connector for the lens’ circuit board from the motherboard.
Remove the two screws for the metal plate on the bottom.
Detach the no fuse ribbon cables by sliding them out.
Detach the ZIF connector cables by flipping the small black holder in an upright position and then sliding the cable out carefully.
