Введение
You will need a 001 screw driver and a pry stick for this repair.
Выберете то, что вам нужно
Remove all screws on the outside of the camera. A total of 6 screws will be removed.
Once all screws are removed slide open the battery cover.
Pop off the front plate of the camera by moving the two pieces away from each other.
Next, remove the two silver screws on the inside of the camera.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use a pry stick to pop out the connector ribbon attached to the LCD screen.
Attach the new LCD screen.
Follow the previous steps in reverse to put the camera back together.
Еще один человек закончил это руководство.
