Введение
This guide will help you to replace the front panel unit on the Sony Cyber Shot DSC-W170.
If the front panel is damaged, the solution is to replace the front panel unit. Be sure to remove power/disconnect batteries before performing this task!
Take a look at our troubleshooting page if you need help to remove the battery.
On the Sony website you can find replacement parts for the camera.
Выберете то, что вам нужно
Remove the five 4 mm screws with a Phillips #000 screwdriver.
