Введение
This guide will help you to replace the LCD panel unit on the Sony Cyber Shot DSC-W170.
If the screen protector or menu buttons are not working properly, the solution is to replace the LCD panel unit. The following is a step-by-step guide to removing the LCD panel unit and replacing it with a working one. Be careful when removing shattered glass displays and be sure to remove power/disconnect batteries before performing this task!
Take a look at our troubleshooting page if you need help to remove the battery.
On the Sony website you can find replacement parts for the camera.
Выберете то, что вам нужно
Remove the five 4 mm screws with a Phillips #000 screwdriver.
