Введение
This guide will help you to replace the top panel on the Sony Cyber Shot DSC-W170.
If the shutter button or the power button are not working properly, the solution is to replace the top panel unit. Be sure to remove power/disconnect batteries before performing this task!
Take a look at our troubleshooting page if you need help to remove the battery.
On the Sony website you can find replacement parts for the camera.
Выберете то, что вам нужно
Remove the five 4 mm screws with a Phillips #000 screwdriver.
Remove the first side panel to the left of the LCD.
Remove the 4 mm screw from the other side panel to the right of the LCD with a Phillips #000 screwdriver.
Gently, lift the LCD and carefully open the camera to disconnect the LCD ribbon cable from the motherboard.
Gently push the connector through the hole to separate the LCD from the metal casing.
Remove the six 4 mm screws from the lens assembly with a Phillips #000 screwdriver.
Peel back the flash assembly on the back of the lens.
Remove the two 4 mm screws with a Phillips #000 screwdriver.
Pull out the battery from the side and remove the white tape from the battery assembly with tweezers.
Disconnect the flat ribbon cable that connects the motherboard to the lens assembly with tweezers.
Remove the 4 mm screw from the bottom side of the top panel with a Phillips #000 screwdriver.
Remove the silver 4 mm screw with a Phillips #000 screwdriver from the silver bracket connected to the motherboard.
