Введение
In order to reach the flashboard unit inside the device you have to first remove the front and back panel, the button board and the top cover of the device.
Выберете то, что вам нужно
Remove the six 3.5mm Phillips #000 screws.
Rotate the lock away from the camera.
Remove the two plastic spacers between the front and the back panels.
Carefully remove the back panel.
Disconnect the no-fuss ribbon cable by gently pulling it out of the button board.
2 участников успешно повторили данное руководство.
