Выберете то, что вам нужно
Slide open the battery cover and remove the battery and the Memory Stick Duo.
Return the battery cover to its closed position.
Press down on the flash cover to raise the flash.
Remove both screws that hold the flash cover to the body of the camera.
Place the camera upside down with the battery port positioned upward.
Slide open the battery port.
Unscrew the screw located at the back left corner of the flash component.
Set the flash component aside.
Еще один человек закончил это руководство.
