Выберете то, что вам нужно
Slide open the battery cover and remove the battery and the Memory Stick Duo.
Return the battery cover to its closed position.
Press down on the flash cover to raise the flash.
Remove both screws that hold the flash cover to the body of the camera.
Place the camera upside down with the battery port positioned upward and the battery port open.
Unscrew the screw located at the back left corner of the flash component.
Set the flash component aside.
Lift up the gray plastic facing in order to uncover the motherboard and the ribbon cable ports.
Carefully flip up the three black clasps holding the lens cables to the motherboard.
Slide the cables from the ports.
Lift the lens and attached ribbon cables from the camera in order to switch this lens with a new one.
Еще один человек закончил это руководство.
