Введение
This guide gives a simple step-by-step process for removing and/or replacing the battery. Battery removal is required for most other repairs of this device.
Push down and away from the camera to the left on the indicated indentation in the battery cover. The compartment should slide open as shown.
Push the blue tab towards the camera body to the right, while simultaneously pulling out the battery.
To reassemble your device, insert the new battery in the compartment, making sure that your battery has the correct orientation, then follow these instructions in reverse order.
