Введение
Replacement of this component will involve the disassembly of the screen's enclosure and careful disconnection of its cable.
Выберете то, что вам нужно
Extend the LCD screen away from the camera to access the screws on the back of its housing.
Place the camera with the lens down.
Tilt the screen upwards to see the screw on the bottom of the housing.
Unscrew this #00 4.0 mm Phillips screw.
Pry the casing apart using your plastic opening tool. Begin by prying at the hole where you removed the screw and continue along the seam.
Lift the transparent section of the plastic housing off.
Lift the rubber screen bumper off of the screen.
Pull up on the screen to reveal the data attachment cable.
Carefully pull the LCD screen away from enclosure to remove the cable and screen completely.
5 участников успешно повторили данное руководство.
5 Комментариев
What is the lcd screen part number? And where can i find it online? I need to replace my dads cracked screen.
lao90227ay
s300gc05lb9e21xmo usp5280371
Display my order
Screen LCDOnline booking
qual tela de lcd posso usar?
não achei
