Введение
If you have a faulty viewfinder and would like to know how to replace it yourself, this guide will show you how to do just that. By following these 6 simple steps, you will have your camera repaired within a few minutes and you will also save a couple of bucks.
Выберете то, что вам нужно
Make sure camera is turned off.
Press the ON/Off button to turn off the camera.
Remove 2 screws from the side of the camera.
Remove 4 screws on the bottom of the camera.
Remove 1 screw next to the eyepiece.
Flip the screen back to reveal 2 hidden screws.
Remove the two 1.59mm #00 screws on the left with the Phillips #00 screwdriver.
Carefully pull out the the eyepiece.
Detach the orange ribbon cable that connects it to the green panel by carefully pulling outwards.
Еще один человек закончил это руководство.
Один комментарий
Thank you very much for the importent articles made for us. If I can please put , how to replace the flasher as well.
