Введение
To replace the flash on your device you are going to have to take quite a bit of pieces out.
Выберете то, что вам нужно
Orient the device so the bottom is facing up, and the lens is facing you ("bottom view").
Remove these two black M1.4 X 3.5 Phillips head screws.
The third, unmarked screw does not need to be removed at this time.
Orient the device so the LCD is facing you, and the hdmi cover is facing up ("left view).
Remove these three black M1.4 X 3.5 Phillips head screws.
Use the plastic opening tool with a prying motion, going between the case and the LCD, from the middle of the LCD to the right of the device, undoing the claws retaining the back.
Unhook the small printed circuit board by gently pressing the board towards the top of the device and lifting up.
Using a plastic opening tool remove the black LCD retainer clip to the right of LCD.
Using the plastic opening tool to lift the black retaining clip up to disengage the ribbon cable. Then gently pull the ribbon cable to remove.
Remove the black M1.4 X 3.5 Phillips head screw in upper right corner of the device.
Service manual for reference: Click to go to the service manual.
Reorient the camera so you are looking at the "top view".
Remove the black M1.4 X 3.5 Phillips head screw next to the ON/OFF button circled in red.
Orient the device so you are looking at the "bottom view".
Remove the black M1.4 X 3.5 Phillps head screw located next to the tripod attachment.
The connections (red squares) have small black retaining clips. Using a plastic opening tool, lift upward towards the cable to unlock.
The upper ribbon cable simply pulls loose.
Discharge the capacitor by connecting the resistor jig between the highlighted squares.
Use tweezers to remove the speaker retaining clip. The retaining hooks locations are indicated, but not exact.
From the top of the camera, Use a plastic opening tool between the flash and the case to remove the flash.
And here is the how the flash module should look after being removed.
This is a reference image: it is possible to further disassemble this module, and is not necessary.
