Введение
Is the View Finder not working even after the LCD/Finder button has been pressed? Then the View Finder may need replacing.
Выберете то, что вам нужно
Turn the camera upside down. This is a view of the bottom of the camera.
Remove the 3 (4 cm) Philips head screws holding the plastic camera housing together. They are located on the back of the camera.
Remove the 2 (4 cm) Phillips head screws on the right side of the camera.
Turn the camera upside down and remove the remaining 3 (4 cm) Phillips head screws holding the plastic housing together.
Remove the 1 (2 cm) Phillips head screw
Remove the 2 (5 cm) Phillips head screws that mount the View Finder to the camera.
Carefully disconnect the ribbon wire that connects the View Finder to the Motherboard.
Еще один человек закончил это руководство.
