Введение
This guide will show you the steps to remove and replace the lens of the camera
Выберете то, что вам нужно
Place the device so bottom of the camera is facing up .
Remove the five marked screws with a Phillips #000 screwdriver.
Insert the spudger where arrow marks to gently remove the lower panel.
Remove the marked screw on the side of the camera with a Phillips #000 screwdriver.
Orient the device so the lens is facing down.
Remove the two black M1.4 X 3.5 Phillips head screws using Phillips #000 screwdriver.
Remove the black M1.4 X 3.5 Phillips head screw.
Use the plastic opening tool with a prying motion to remove the side cover of the camera.
Remove the small screw under the multi/USB cover.
Use the plastic opening tool to remove the button board.
Disconnect the control board data cable by wiggling carefully with your fingertips. Set the control board to the side once it is disconnected.
Lift the metal plate and LCD screen simultaneously until it is perpendicular to the camera.
Remove the ribbon cable connecting LCD display to camera sensor and battery housing.
Press on the lens with your finger.
Gently pull the lens container out of the camera.
8 участников успешно повторили данное руководство.
5 Комментариев
Aside from a few missed screws, very nicely done. And I suspect that if one didn’t realize the need to remove those screws, sh/e probably shouldn’t be attempting the job in the first place. :) (I noted the comments after completing lens removal.)
Can you comment where/specifically the missing screws that were not listed can be found? Any other guides out there that are more comprehensive?
Eric C -
