Sony Cyber-shot DSC-HX9V LCD Screen Replacement
Выберете то, что вам нужно
  1. Sony Cyber-shot DSC-HX9V LCD Screen Replacement, Battery: шаг 1, изображение 1 из 1
    • Ensure the camera is powered off prior to removal of the battery. The LCD screen will have no information displayed if the camera is properly turned off.
    • Place the camera upside down with the top sitting on a flat surface.
    • Using your fingers, slide the door lock to the unlock position.
  2. Sony Cyber-shot DSC-HX9V LCD Screen Replacement: шаг 2, изображение 1 из 1
    • Open the battery compartment door.
    • Remove the battery from the compartment by turning the camera upside down and allow it to slide out. Be sure to catch the battery as it slides out.
    • If you are replacing internal camera parts, stop here. If you are replacing the old battery, continue with step 2.
    • Sony recommends the use of an approved battery for maximum performance. The recommended battery model number is NP-FG1.
    • Insert the new battery into the compartment matching the positive battery lead to the positive terminal and the negative battery lead to the negative terminal on the camera.
    • Close and lock the battery door and power the camera up. Ensure to check the battery charge levels and that all functions of the camera work properly.
  3. Sony Cyber-shot DSC-HX9V LCD Screen Replacement, Rear Case: шаг 3, изображение 1 из 1
    • The screws are very small and may become lost during removal. It is recommended to store the screws in a Ziplock bag or container until it is time to reassemble.
    • Place the camera on a towel while working on top of a desk or table.
    • Remove the five marked screws with a Phillips #000 screwdriver.
  4. Sony Cyber-shot DSC-HX9V LCD Screen Replacement: шаг 4, изображение 1 из 1
    • In addition, remove the two marked screws with a Phillips #000 screwdriver.
  5. Sony Cyber-shot DSC-HX9V LCD Screen Replacement: шаг 5, изображение 1 из 1
    • Slide the side cover downward once all screws are removed and place it to the side.
  6. Sony Cyber-shot DSC-HX9V LCD Screen Replacement: шаг 6, изображение 1 из 1
    • The marked screws will loosen the rear case and the LCD screen may shift. The use of a soft work surface will prevent the LCD screen from breaking if it accidently shifts during the removal process.
    • Remove the two marked screws with a Phillips #000 screwdriver.
  7. Sony Cyber-shot DSC-HX9V LCD Screen Replacement: шаг 7, изображение 1 из 1
    • Once all the screws are removed, partially lift the rear case upward and install a rubber band.
    • The LCD screen will be loose. The use of a tight fitting rubber band will prevent the LCD screen from sliding. The rubber band will only be temporary.
    • After installation of the rubber band, open the HDMI dust plug located on the right hand side of the camera and continue to tilt the rear case backwards until it is removed.
  8. Sony Cyber-shot DSC-HX9V LCD Screen Replacement: шаг 8, изображение 1 из 1
    • The control board will be loose. Take note to the orientation of the board to aid with installation.
    • Partially lift the control board up from the accessory cage.
  9. Sony Cyber-shot DSC-HX9V LCD Screen Replacement: шаг 9, изображение 1 из 1
    • Disconnect the control board data cable with care. Permanent damage may occur to the control board if tools are used to disconnect the data cable. Use your fingers only.
    • Disconnect the control board data cable by wiggling carefully with your fingertips. Set the control board to the side once it is disconnected.
  10. Sony Cyber-shot DSC-HX9V LCD Screen Replacement, LCD Screen: шаг 10, изображение 1 из 1
    • LCD screen is very fragile. Handle with care. Do not use tools to remove the screen.
    • The LCD screens rests against a metal plate. Lift the metal plate and LCD screen simultaneously until it is perpendicular to the camera.
  11. Sony Cyber-shot DSC-HX9V LCD Screen Replacement: шаг 11, изображение 1 из 1
    • Use caution when handling the data cable. Excessive force will permanently damage the cable.
    • Using one hand, carefully rock the data cable in a side to side motion to disconnect it from the mainboard. Ensure your other hand is holding the screen to prevent damage.
    • Store the LCD screen on a padded surface with the screen facing downward. This will prevent any damage to the screen if tools or items were accidently dropped on it.
Заключение
5 участников успешно повторили данное руководство.
Kris
Участник с: 10/26/16
587 Репутация
Автор 4 руководств
Команда
UW Tacoma, Team 1-2, Rose Fall 2016 Участник UW Tacoma, Team 1-2, Rose Fall 2016
UWT-ROSE-F16S1G2
4 членов
Автор 12 руководств
4 Комментариев
My camera was dropped recently and now no display appears. The camera was in a protective case but hit the ground, just right, on its corner. This looks like a great procedure for repair. However, where would I procure a replacement screen? Do you have a part number? Thank you!
Bill Turner - Ответить
I recently dropped my camera and now there’s no display. The camera was in a protective case but landed, just right, on it’s corner.
This procedure looks great. However, where would I procure a replacement LCD screen? Do you have a part number? Thanks!
Mijn display in mijn camera was volgens mij aangetast door vocht en was niet meer helder en gebruiksvriendelijk. Met een nieuwe (misschien wel occasion) uit china is hij weer prima te gebruiken. Dank voor de uitvoerige en precieze beschrijving om deze reparatie uit te voeren. Hulde aan schrijver Kris.
Yann van Tol, Den Haag, 28.08.2018
Yann van Tol - Ответить
Hello @jetblast Thanks for this guide. Flash of my HX9V is not working properly. It actaully popus up but doesn’t throw the white light. I got it checked in the Sony Service center and this is what they suggested me to change: http://prntscr.com/qidtm4 Can anyone identity these two parts and from where I can get them? Also, any repaid guide available on how to change the flash?
Thanks in advance!
Raj - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 11
За последние 30 дней: 61
За всё время: 4,278
