Sony Cyber-shot DSC-P52 Lens Replacement
Выберете то, что вам нужно
  1. Sony Cyber-shot DSC-P52 Lens Replacement, Outer Case: шаг 1, изображение 1 из 1
    • Open the battery compartment and remove the batteries.
    • Remove all of the visible screws on the outside of the case.
    • There should be three of them that are all easily located.
  2. Sony Cyber-shot DSC-P52 Lens Replacement: шаг 2, изображение 1 из 1
    • Open the memory card compartment.
    • Remove the screw next to the memory card slot.
  3. Sony Cyber-shot DSC-P52 Lens Replacement: шаг 3, изображение 1 из 1
    • Pull apart the front and back cover pieces carefully.
    • The front cover should come completely free with little effort.
    • The back cover will still be attached to the circuit board.
  4. Sony Cyber-shot DSC-P52 Lens Replacement: шаг 4, изображение 1 из 1
    • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • The circuitry will still be connected to the back case by ribbon cables.
  5. Sony Cyber-shot DSC-P52 Lens Replacement: шаг 5, изображение 1 из 1
    • Open the case as shown.
  6. Sony Cyber-shot DSC-P52 Lens Replacement: шаг 6, изображение 1 из 1
    • Unclip the clip holding the ribbon cable in.
    • Other ribbon cables might not have a clips.
  7. Sony Cyber-shot DSC-P52 Lens Replacement: шаг 7, изображение 1 из 1
    • Pull the ribbon cable out.
  8. Sony Cyber-shot DSC-P52 Lens Replacement, Lens: шаг 8, изображение 1 из 1
    • Remove the two additional screws on the back of the lens.
  9. Sony Cyber-shot DSC-P52 Lens Replacement: шаг 9, изображение 1 из 1
    • Detach the ribbon cables and unplug the cable leading to the back of the motherboard.
  10. Sony Cyber-shot DSC-P52 Lens Replacement: шаг 10, изображение 1 из 1
    • Remove the motherboard and the flash from the rest of the hardware.
  11. Sony Cyber-shot DSC-P52 Lens Replacement: шаг 11, изображение 1 из 1
    • Remove the screw indicated in the picture to detach the lens and the viewfinder from the other hardware.
  12. Sony Cyber-shot DSC-P52 Lens Replacement: шаг 12, изображение 1 из 1
    • Remove the three screws shown to separate the lens from the viewfinder.
  13. Sony Cyber-shot DSC-P52 Lens Replacement: шаг 13, изображение 1 из 1
    • Purchase a new viewfinder.
    • Repeat the previous steps in reverse order to rebuild.
Заключение
Еще один человек закончил это руководство.
Kari Johnson
Участник с: 01/10/11
127 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 3-43, Regan Winter 2011 Участник Cal Poly, Team 3-43, Regan Winter 2011
CPSU-REGAN-W11S3G43
4 членов
Автор 20 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 7
За последние 30 дней: 22
За всё время: 1,333
