Sony Cyber-shot DSC-P52 Motherboard Replacement
Выберете то, что вам нужно
  1. Sony Cyber-shot DSC-P52 Motherboard Replacement, Outer Case: шаг 1, изображение 1 из 1
    • Open the battery compartment and remove the batteries.
    • Remove all of the visible screws on the outside of the case.
    • There should be three of them that are all easily located.
  2. Sony Cyber-shot DSC-P52 Motherboard Replacement: шаг 2, изображение 1 из 1
    • Open the memory card compartment.
    • Remove the screw next to the memory card slot.
  3. Sony Cyber-shot DSC-P52 Motherboard Replacement: шаг 3, изображение 1 из 1
    • Pull apart the front and back cover pieces carefully.
    • The front cover should come completely free with little effort.
    • The back cover will still be attached to the circuit board.
  4. Sony Cyber-shot DSC-P52 Motherboard Replacement: шаг 4, изображение 1 из 1
    • Simultaneously unclip all of the clips holding in the circuitry. Remove the back case.
    • The circuitry will still be connected to the back case by ribbon cables.
  5. Sony Cyber-shot DSC-P52 Motherboard Replacement: шаг 5, изображение 1 из 1
    • Open the case as shown.
  6. Sony Cyber-shot DSC-P52 Motherboard Replacement: шаг 6, изображение 1 из 1
    • Unclip the clip holding the ribbon cable in.
    • Other ribbon cables might not have a clips.
  7. Sony Cyber-shot DSC-P52 Motherboard Replacement: шаг 7, изображение 1 из 1
    • Pull the ribbon cable out.
  8. Sony Cyber-shot DSC-P52 Motherboard Replacement, Motherboard Assembly: шаг 8, изображение 1 из 1
    • Remove all six screws on the front side of the motherboard circled in the picture.
    • Pull the motherboard from the rest of the housing.
    • It will still be connected to the flash unit.
  9. Sony Cyber-shot DSC-P52 Motherboard Replacement: шаг 9, изображение 1 из 1
    • Remove the cable on the back side of the motherboard.
  10. Sony Cyber-shot DSC-P52 Motherboard Replacement: шаг 10, изображение 1 из 1
    • Detach the ribbon cables shown.
    • Careful! Touching the leads of the large yellow capacitor can result in a painful shock.
    • Remove the flash unit from the motherboard.
  11. Sony Cyber-shot DSC-P52 Motherboard Replacement, Motherboard: шаг 11, изображение 1 из 1
    • The motherboard is now free, and ready to be replaced by a new one.
Заключение
Еще один человек закончил это руководство.
Trevor
Участник с: 01/20/11
295 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 3-43, Regan Winter 2011 Участник Cal Poly, Team 3-43, Regan Winter 2011
CPSU-REGAN-W11S3G43
4 членов
Автор 20 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 1,159
