Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Выберете то, что вам нужно
Slide the battery latch down the side of the camera with your hands.
The latch will automatically pop open.
Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
Once the screws are removed, slowly remove the back casing from the rest of the camera.
Remove the 3.0mm Phillips #000 screw above the battery door on the side of the camera.
Pull off the pieces of casing located on either side of the top button of the camera.
Remove the top button piece. You will need to detach a small blue ribbon cable before the button can be fully removed.
