Введение
Follow this guide for the process of replacing the CCD chip, which is responsible for converting light into digital images. For safety reasons, battery should be first removed.
Выберете то, что вам нужно
Locate the cover on the bottom of the camera.
Slide the cover towards the back of the camera.
Locate and remove the 3mm screws on the bottom and sides of the camera with a JIS size #0 screwdriver.
Pull the two halves of the camera apart.
Place the two halves down with the insides facing you.
Find the two clips holding the motherboard to the black lens box.
Slide the plastic opening tool in between the ribbon and the black part of the clip, then flip it up. (If difficult, your fingernail can also be used)
Locate and unscrew the two 3mm screws on the bottom of the black lens box with the JIS #0 screwdriver.
3 участников успешно повторили данное руководство.
