Введение
Having problems with the camera flash? Replacing the Flash Module is easy!
Запчасти
Никакие детали не требуются.
  1. Locate the battery door at the bottom of the camera. Press down on the door and  slide it back.  The door will pop open.
    • Locate the battery door at the bottom of the camera.
    • Press down on the door and slide it back. The door will pop open.
  2. Remove the battery from the door that you opened in the previous step.
    • Remove the battery from the door that you opened in the previous step.
  3. There are two screws on the left and right sides of the camera, and two screws on the bottom. Use a PH00 screwdriver and remove the six 2.9mm screws. Use a PH00 screwdriver and remove the six 2.9mm screws.
    • There are two screws on the left and right sides of the camera, and two screws on the bottom.
    • Use a PH00 screwdriver and remove the six 2.9mm screws.
  4. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  5. Use hands to gently pry the front casing away from the camera. Use hands to gently pry the front casing away from the camera.
    • Use hands to gently pry the front casing away from the camera.
  6. Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable. The second picture shows what these tabs look like in their open positions.
    • Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
    • The second picture shows what these tabs look like in their open positions.
  7. Grasp the CCD Sensor Module and remove it.
    • Grasp the CCD Sensor Module and remove it.
  8. This camera houses a very strong capacitor (the black cylinder).  Avoid touching anything around the two wires coming out of the top.  Doing so will risk serious electric shock. Carefully disengage the internal components from the casing by lifting at the bottom end and giving a gentle tug. The components are still connected to the casing via cables, but they are much more maneuverable.
    • This camera houses a very strong capacitor (the black cylinder). Avoid touching anything around the two wires coming out of the top. Doing so will risk serious electric shock.
    • Carefully disengage the internal components from the casing by lifting at the bottom end and giving a gentle tug.
    • The components are still connected to the casing via cables, but they are much more maneuverable.
    • The flash module is shown on the right hand side.
  9. Use the tip of a spudger to flip up the tab on the ZIF connecter securing the motherboard ribbon cable. Grasp the flash module by the bottom and remove it.
    • Use the tip of a spudger to flip up the tab on the ZIF connecter securing the motherboard ribbon cable.
    • Grasp the flash module by the bottom and remove it.
Заключение
iDeleted
Участник с: 07.07.2010
2 101 Репутация
Автор 39 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 2
За 7 дней: 4
За 30 дней: 5
За всё время: 2,174
