Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Taking out the LCD is one of the more difficult things to do on your Cyber-shot. Because the LCD is located at the back of the camera you will have to take apart the entire camera just to reach it.
Выберете то, что вам нужно
Locate the battery door at the bottom of the camera.
Press down on the door and slide it back. The door will pop open.
Use a PH00 screwdriver and remove the six 2.9mm screws.
Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
The second picture shows what these tabs look like in their open positions.
Use tweezers to slide the white piece on the back of the back cover to the right.
This will dislodge the white piece, allowing you to remove it from the back cover.
Remove the ribbon cables from these two ZIF connectors.
Lift the motherboard assembly up and rotate it so you can easily see where the internals connect to the back cover.
Remove the ZIF connectors from the clamp on the left end of the top piece.
The motherboard assembly is now separated from the back cover.
Use a PH00 screwdriver to remove the 2.9 mm phillips screw on the upper left side of the case.
Remove the back frame from the LCD assembly.
Turn the LCD assembly over and gently pull the top bar off (which has the shutter and power buttons).
