Введение
The back cover needs to be removed for most other repair guides in order to access more parts within the camera.
Выберете то, что вам нужно
The battery cover is located on the right side of the camera.
Slide the cover to expose the battery.
Ensure that the battery lines up properly with the slot in the camera.
Slide battery in.
Slide cover closed.
Remove screws from outside of camera. There are 6 screws total.
3 screws on underside.
1 screw on right side, near battery cover.
2 screws on left side.
Gently pull the front cover off of the main camera.
All of the inner parts of the camera are attached to the back screen.
The front cover is now removed from the camera and the internal hardware is now exposed.
Remove tripod piece located at the bottom of the camera. This piece should slide out with ease.
Slide open the top panel. This is located on the top of the camera, where the power button and shutter button are.
