Введение
This guide will allow the user to remove the front cover of the camera, necessary for most other steps.
Запчасти
Никакие детали не требуются.
  1. The battery cover is located on the right side of the camera.
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Ensure that the battery lines up properly with the slot in the camera.
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. Remove screws from outside of camera. There are 6 screws total. 3 screws on underside. 1 screw on right side, near battery cover.
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  5. Use screwdriver to remove screws.
    • Use screwdriver to remove screws.
  6. Gently pull the front cover off of the main camera.
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  7. The front cover is now removed from the camera and the internal hardware is now exposed.
    • The front cover is now removed from the camera and the internal hardware is now exposed.
Заключение
Stephannie Allen
Участник с: 11.03.2013
189 Репутация
Автор 10 руководств
Команда
Clemson, Team 13-1, Benson Spring 2013 Member of Clemson, Team 13-1, Benson Spring 2013
CLEM-BENSON-S13S13G1
4 членов
Автор 10 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 4
За всё время: 255
